Originally Posted by suicideneil
Insert a center punch into the hole in the bearing, then tap it that way- should pop right out or fall to bits, but it'll come out all the same
Are the bearings bad, or are you just upgrading from the start?
Thanks, I'll try and let you know.
No, the stock bearings are ok, just upgrading to a pair of Boca Bearing hybrid (steel + ceramic) bearings
Bye, Andrea.
