crazyjr
crazyjr's Avatar
04.30.2010, 08:30 PM
Novaktwo, I think the 550 size will have the same problem i am having with the lehner. You see, i am running the lehner 1200 basic XL in an rc10 GT converted to electric, The diff outputs have spread to the point that the dogbones slip. I am trying to lower the torque but, keep the efficiency, This is why the low KV/higher voltage smaller rotor setup. I am also intrested in using the sensored setup as well. I also believe the 550 in a kv i want would be very expensive, I am aiming for 1100 to 1500 kv. Thank you for the responce
