05.01.2010, 09:22 AM
Maybe the metal tab(s) inside the deans plug got misaligned and arent making contact anymore when you plug it into the harness from the esc? You could test by just shorting across one of the male plugs with a bit of wire and plugging the batt into the other, then see if the esc will arm..
