05.01.2010, 12:15 PM
Does it still connect with the Castle Link? I thought the red blinking light was "wrong # of cells set" or something like that. Is the single pack you want to use the same voltage as the 2 series packs you were using? If not, hook it up to the CL and change the LVC setting and see if that helps.
