A RC Dude
A RC Dude's Avatar
05.02.2010, 11:35 PM
the track is a 4x8ft sheet of .030mil lexan painted with yellow paint (the same paint as for rc cars) that is cut out in strips/curves 1in wide wile a copper ground wire hot glued underneath it to support it. the cars are each 3 differant HO scale model train tracks. i used roller bearing trucks for the center and two walthers trucks (brass axle with plastic wheels) on the sides. but youve got to move the wheeles on the side trucks around. i'll get a better picture later, i need to get to bed now. then the car on top of the trucks are thin peices of balsa wood that have been cut out and glued togather. each car is held togather by a cut o-ring thats been glues with gorilla glue onto the bottom of the cars.
the lexan came from granger, paint and trucks from hobbie shop, wire and glue from a hardware store. then it's a k-nex chain, shelving braket (i think that's what it's called) as the chain sleeve, k-nex gears and frame at the bottom, vex kit motors (soldered +/- wires directly to the motors) for the chain and station, vex kit gears for the top of the chain and the mechanical timer for the station (the train will stop in the station for a little bit, then the motor turns on, pushing the train out), and station, lego wheel with rc car foam tire inseart for the station start/stop wheel. and that's pretty much it
Originally Posted by TexasSP View Post
Man that was fast. I imagine in scale speed you would be close to mach 1. Seriously though, nice work again!
haha thanks! it doesn't seem as in person though. but the last curve that i had to change, it it was only an inch higher, it wouldn't make it. that's how fast it gains and looses speed.
