Thread: 1/6 bl-lst
mistercrash
Guelph, Canada, eh!
mistercrash's Avatar
05.04.2010, 01:09 PM
You are an inspiration. This build is extraordinary. Makes my builds look like child's play. I don't use a CNC, I don't have the knowledge to use them (yet) or the CNC machining either. I do most of the stuff by hand but for cutting CF, diamond disks make a very clean cut. For making holes and counter sinking, Carbide or Tungsten carbide bits and end mills cut through CF like butter and also make very clean cuts. I can only use high speeds because I make the cuts with a cheap router on a small router table and it only has one speed, fast
Thank you for sharing this build, it is truly wonderful.
No brain, no headaches.
