Jahay
05.06.2010, 08:14 AM
Ok a few things... need a little advice and confirmation...
As you know iam going to try an 8s configuration... to keep things balanced, in the truck,
I am going to buy 2x2s and one 4s lipo. And place the 4s in the centre of the chassis and the 2x2s either side in battery boxes by kershaw.... I will be using bullets and was wondering if it is ok to connect them this way...
Also im not sure if im going for the HV any longer as i am a little worried it will over heat as it will not get the same air flow like it would on a plane... Or is this not the case..???
This was brought to my attention and the ESC in the link below has a built in fan which should be more suitable right?
http://mgm-compro.com/index.php?tid=...-boat-z-series
Does anyone have any experience with this item or no much about it???
THANKS
