05.09.2010, 10:42 PM
Great, as soon as I reply to your thread I'm having my own BEC issue now with my new MMP. Just got all the connectors soldered up and ready to go today. Connect everything up, turn it on, try to test the steering, and the RX (SR300 also) is going out when I turn the wheels. The only way I can get the wheels to turn without shutting down the RX is go very slowly. Tried with two different servos and it does the same thing, and neither of them are particularly high power servos.
I might try a cap like you did and see if that helps, otherwise the question is do I send it back to Castle or just use an external BEC?
