Chadworkz
UE Supermaxx Addict!
Chadworkz's Avatar
05.10.2010, 08:01 PM
Smaller Pinion (less teeth) = Lower Gearing (more torque, longer run-times)
Larger Pinion (more teeth) = Higher Gearing (more top-speed, shorter run-times)
Smaller Spur (less teeth) = Higher Gearing (more top-speed, shorter run-times)
Larger Spur (more teeth) = Lower Gearing (more torque, longer run-times)
-Chad
PM ME IF YOU HAVE THE BELOW:
