jholthus
05.10.2010, 08:26 PM
Originally Posted by hootie7159 View Post
Did you happen to buy the roller with 17mm adapters with black rimmed buggy wheel?...if you did it was mine...i stripped my spur gear because the top set screw holding the motor down kept backing out...either I need to put locktite on the screw or the motor was waaay to big/heavy. Anyways, the gear mesh would get messed up everytime the motor moved...I ran it with mmm/2200k combo on 4s and it was almost too much.
Nope wasn't yours. I appreciate the fast response guys. Thanks.
