Chadworkz
UE Supermaxx Addict!
Chadworkz's Avatar
05.13.2010, 01:46 AM
Originally Posted by mistercrash View Post
Since I have the T6 6061 alu sheet, I thought I would make a template of the final top plate that will help cutting the 2.5 mm CF plate that finally came in this morning. The CF plate is almost finished. I will post pics when it's done and then I should be able to start assembling the truck.
WOW, just WOW! You did an excellent job on that upper template! Even though it is just a template for making the final CF part, the aluminum template is flawless, and worthy of being the main upper plate in any build! Anyone would be happy to run that top-plate and show it off...you did an amazing job on it!
-Chad
PM ME IF YOU HAVE THE BELOW:
