Thread: Revo conversion
05.13.2010, 09:52 AM
I would not bother with 4s. Even 5s is a bit slow on motor speed. Stick with 6s and gear for 45mph. You will be happy. Trying to setup a vehicle to use different voltage is a waste of time. As far as running temps, set it up as advised and run it while checking your temps with a temp gun. If you do not have a temp gun buy one.
6s will put you right at 30k motor rpms under load.
