itbvolks
05.14.2010, 11:31 AM
What are the dims? They share the same can/rotor specs as the 1515 series?
How have your temps been with that motor? I'm running similar setup to you (1700kv on 5s with 16/46 gearing) and I'm pretty happy with the T8 setup but wouldn't mind hearing more about the nue motor setup.
Sounds like your efficiency is pretty good too based on your run time and batt capacity.
Are you running any varied throttle profile on the RX8? How's your response running sensorless with the neu? Still pretty smooth?
The nue 1518 is also interesting. Several options there for winds.
