Thread: My First Savage
Finnster
KillaHurtz
Finnster's Avatar
05.17.2010, 10:52 AM
BTW, since I have 4WS, I mounted the shocks in the rear. They work fine either direction.
the only thing I don't like about the LST/AS shocks on the savage is that the lower shock end only mounts w. a 4mm screw and hangs away from the arm a bit by a spacer. As a consequence, the 3mm screw gets bent over time. I don't see that the FLM arms really change this either.
Add a better lower mount the the list of possible improvements to some FLM arms. :)
