Originally Posted by Arct1k
Is there any way of "telling" if the ESC recognizes it is joined with a Novak motor and hence protection is enabled.
I don't want to run into the same issue again...
Our copy will explain that only Novak motors will run with certain Novak escs. As I said, only the Havocs (listed above) currently have fixed, TOP sensors enabled. In the early GTB days, racers either cut, or unplugged the blue wires to circumvent the TOP.
However, disabling the blue wire in these Havocs will prevent them from running at all....Live and learn.
