05.17.2010, 09:03 PM
Interesting - this is definately NOT the case with any one I have seen. I know that the holes are pretty true, so if the bearing is even slightly out of alignment it will appear as though it doesn't fit, but every one I just test fit(after reading, I checked a handful of the remaining stock), the bearing presses in perfectly(slight drag, but no excess force required to install). I do apologize if you got a tight bearing hole, but I assure you that it is a very rare occurrence and not indicative of the anodized mount, as the Muggy mounts have been anodized for a while now. :)
