Originally Posted by E-Revonut
Whats with all the zipties on the motor?
I had an incident when I first built the truck where I didn't set the pinion back far enough and when the motor spooled up, there was just enough rotor-float to allow the pinion to come forward enough to get into the slipper, which torqued the motor forward and to the side, bending the RCM motor-mount (which Mike replaced for free, by the way). I now use zip-ties to hold the motor tightly against the rear cradle and brace.
