05.19.2010, 10:58 PM
I am using a RCM pinion, and I put a thin spacer plate between the motor and mount to give enough clearance for the shaft. Clearance to the radio box is about 1 to 1.5mm, pretty darn close. The RCM conversion kit has a radio box that gives much more room for pinion clearance, I may get one in the future just to make motor/pinion changes easier.
