pinkpanda3310
pinkpanda3310's Avatar
05.20.2010, 09:46 AM
Originally Posted by PBO View Post
I do understand Jerry's point
There's a lot of different ways to consider the issues he raises. I don't know that fortifying your community is the solution though. PP do you think it's the best solution to dealing with the issue...do you feel you need to do it to feel safe?
I feel safer here in Perth than if I were in Arizona. The large mass of water around us ,PBO, is much like a wall or barrier of sorts. I consider the influx of illegals in Arizona may well be the same as all Australia if it had a wall. So yes, I would feel better to build a wall, if I were there.
