Originally Posted by simplechamp
Yes you could, that is exactly what I was using before I found the router and table. The thing I didn't like about the Dremel table though was that it had too much flex and the Dremel moved. But it can be done, like it was said, you just have to go slower. I used to take off as much material first freehand leaving 1/16'' all around the part so that the Dremel wouldn't have to work too hard.
