sikeston34m
sikeston34m's Avatar
05.21.2010, 07:06 AM
Originally Posted by notnodak View Post
I just got my MMPro in the mail today and will be mounting it in a 3905. The MM it's replacing is held by the two factory ESC screws and it works perfect but the Pro might be a different case size so..... What is the CLEANEST way to mount a MMPro in a 3905?
I'll tell you what I did.
Get a MMM Mount, then use velcro underneath it also.
The MM Pro is just a little shorter than the MMM, so the velcro aids in holding it, plus helps take up that little bit of extra space.
Plus you have a place to mount the ON/OFF switch.
