Laptop Battery Technology in a BoomBox Stereo?
sikeston34m
sikeston34m's Avatar
Laptop Battery Technology in a BoomBox Stereo? - 05.22.2010, 02:20 PM
Hi Guys,
I just snagged one of these off the Bay.
I'm pretty excited about it, since it's loaded with features. It will accept an Ipod, or any Mp3 player, but since it also accepts Memory Sticks as Mp3 media, that's probably what will be used the most.
It also has a remote, which is pretty cool.
The nostalgia factor is also really nice.
All of it's features isnt' really what this thread is about though.
A Laptop has it's own lithium ion pack, with cell protection. You don't have to take out the pack, or plug it into to a separate charger. You don't even have to make a conscious effort to charge it. It just does it automatically.
This Boombox takes 10 "D" size cells. We all know it's gonna eat those for lunch. No I say! Let's make it better. Let's put it on Lithium Ion.
Now 10 expensive "D" cells fresh out of the pack will be 15 volts.
There is an acceptable voltage range of operation on this unit, so before the unit starts cutting out from low battery voltage, I'm thinking this will occur around 9 volts or so.
I'll be sure to check the AC transformer voltage to double check. But I'm thinking it will be a regular 12 volt transformer.
This puts things in line for 3S Lithium/Lipo operation.
Lipo can be used as long as it has some sort of protective circuit board installed that monitors voltage.
I thought about this route until I acquired a quantity of "new" old stock on some cell phone batteries.
That's when I came up with this.
Each cell phone battery has it's own pcb. Eureka! That problem is solved.
The picture shown is a 1S configuration at around 30,000mah. I will build another pack similiar to this, only in 3S configuration. Totol Mah of the new pack will be determined by battery compartment size. (How many will fit) LOL
Now, we want a separate charge circuit that keeps the battery pack topped off for as long as the unit is plugged into AC.
When the unit is unplugged, it will run on the Battery Pack.
As soon as the unit is plugged into AC, charging will resume, without pushing any buttons or anything.
I have a 1 amp lithium charger that plugs into the wall. It's not a balance charger or anything like that. It is simply constant current up to 12.6 volts (3S).
I plan to install the charger inside the BoomBox, wired to the incoming AC power.
Question: When the unit is unplugged from the AC, will the charger transformer drain energy from the battery pack? If so, what diode configuration will cure this issue?
What do you guys think? Please feel free to chime in and express your opinions/ideas.
