Freezebyte
05.23.2010, 03:51 PM
After owning both, a Flux last year and a 5T this year, im starting to think about going back to a Flux. I've compiled my personal experience comparison with pro's and con's last night and im trying to decide what to do.
HPI Baja 5T
Pluses:
Very long run times
Awesome noise/smell factor
Attracts a lot of attention
Big and bad
Can be drivin in wet/cold weather with no adverse effects
Nothing else like it
2WD is pretty fun
Minuses:
Expensive to maintain
Not able to jump very high
More prone to breakage and costly repairs
Constant need to be checked, cleaned
Heavy and bulky to move and carry around
Oil/gas spills can be a real mess
Hard to find area's decent enough to run in
Noise factor increases chance of annoying people
Noise factor also decrease's areas can be run in
Takes longer to clean
Tires wear out quicker
Tuning can be become problematic
Constant need for air filter to be checked/cleaned
No reverse
Large and complex to work on
Difficult to find decent area's to run in
FM radio needs to be upgraded
Bodies are expensive to buy and paint
Concrete wears out tires quickly
Dogboots wear out fast
Drive out of town for non ethanol gas
Requires large area to work on
Hard to land jumps correctly, not mid air controllable
Engine will require rebuild after awhile
Requires more upfront cost for durable parts
2WD harder to control
HPI Savage Flux HP
Pluses:
Very fast, agile
Very durable
Can take extreme punishment
Can do insane jumps and landings
Able to be controlled in mid air
No noise pollution to worry about
Can climb pratically anywhere/anything
Cheaper to maintain
Can be programmed via PC *nerd points!*
Parts are usually cheaper
Tires last longer
Smaller and easier to move around
Has reverse
Less complex to work on
No airfilter maintenance
Includes decent 2.4ghz radio and bulletproof diffs now
Easier to bash with Lee's Stampede
Cheap, paintable bodies
Can wheelie easily
Can easily be driven on concrete
Able to be run in variety of area's
No dogboots to maintain
Takes up less workbench space
4WD brushless powa!
Minuses
Lipo's can be expensive and require babying
Shorter run times
Not the same "cool" factor as Baja
Not as fun to work on/tweak
6S Lipo could result in more part breakages
Running in wet/cold weather not recommended
Requires expensive charger
Needs more batteries for longer run times
