allbloody
05.25.2010, 12:41 PM
Originally Posted by Chadworkz View Post
You can run the 8mm CVDs in the 15mm knuckles with the use of 8x15x5 bearings. They are a little bit difficult to find, but they are out there...and you can run them until you find a set of 16mm knuckles. Or, some people have successfully milled the knuckles to 16mm, so if you have a local machine shop, you could go that route. Maybe Mike might do it for you, as I am sure he can do it right.
really, i didnt know they made that size of brg's?? the milling would probably be the best bet, because brgs are easy to find that size.
