jpoprock
"Don't act like you're not impressed."
jpoprock's Avatar
05.25.2010, 01:19 PM
The reason he was doing it upside down was so that the non-cutting portion of the bit was acting as the guide. If you wanted to do it the other way around, you would need a bit with a guide bearing on the end of it - which only come in 1/4" diameter or larger. If you dont have any radii smaller than 1/8'' (half the 1/4" dia) then your fine.
Regarding gloves and power equipment. General rule of thumb is to NEVER wear anything that can get caught in a moving part and pull your body parts into the blade. However, with CF, you have that nasty dust and slivers to contend with. Plus the gloves he had on were more likely to tear than pull - but as close as his finger got a few times, I bet he would have ended up with a nasty little chunk taken out of the finger. Personally, I would do it without gloves, or maybe even try some of those rubber sewing thimbles.
ps. Check your local Craigslist before you go buy a new one. A variable speed router would also be very beneficial for projects like this.
Thanks man. Yes... I can't have chunks taken out of my hands... because I play guitar in a band on the weekends. For MONEY. So... I can't be getting hurt!
It just seems strange to have to work upside down like that. I would spend more time worrying about what areas I wasn't getting to, flipping and checking, and maybe wasting time. But over time, I'm sure it will be easier. I have a variable speed DREMEL, but no router/table. I may have one my father in law will give me though, so that will be nice. I have checked Craigslist... and you can get a nice set up for $200. But don't I have to find a router that has a 1/4" or less chuck on it?? Some of them have bigger ones. But then again... that's max size, not minimum size. I'll just use my dremel collet to use the 1/8" bit.
ERBE: RCM 1/8 Hybrid Diffs, NEU 1515/2.5d/S MMM, 6S, Losi E-XXL CUSTOM, Neu1515 2.5d, MMM, 6s E-SLAYVO PRO ERevo Chassis w/ Pro 3.3 parts, NEU 1512, MMM, 4S.
  Send a message via Yahoo to jpoprock Send a message via AIM to jpoprock
