ANGRY-ALIEN
ANGRY-ALIEN's Avatar
05.25.2010, 10:54 PM
Continuing with my updates on the rebuild... I have manged to finish my 'homemade' CD/motor mount... It was my first attempt on milling with an actual mill... a little different
from sticking a milling bit in dremel and hacking away on the material... the finish wasn't perfect, but i'm sure to get more function than form with this mount... so finished the surface
with a file, sandpaper and scotch brite. got it all bolted up together and feels great... it's a lot more sturdy than my previous attempts... there is no play
at all from the mount... photos of the mount layout below.
I also got the suspension all mounted up... I love the look of these Widetracs... feels a lot smother that the prolines and offers a few more setup options... see the photos below.
UE Widetrac Control Arms, FLM Bulks, UE Super Shocks and UE Knucklehead shock towers
My new homemade CD/Motor mount with a OFNA Spider center diff and CC 1520 attached
Oops!! I accidentally cut the grub screw access slot on the wrong side
Cutting the upper plate for the CD with a dremel cutoff wheel
Upper plate finished and mount mounted
more to come...
