Originally Posted by enlighten
Ah this thing has been shelved for too long! Had a crazy start to the year.
Silent Bob the dimensions are roughly 26mm wide and 150mm long. Max height while still using the plastic cover over the top is 48mm but you can go higher if you remove it and use straps. Sorry for the delay getting back.
That new motor mount looks awesome! I had heaps of trouble setting the mesh with the forward facing motor mount screws, this looks easy as! Thanks for the links.
I cancelled my MMP order from tower back in march after being on back order for months. Just saw it in stock so its time to get this thing up and running.
Cheers All.
Thanks for those dimensions.
