Ryu James
Ryu James's Avatar
05.31.2010, 02:17 AM
Originally Posted by Andrewg View Post
Water cooling vs air or Neu v Lehner?
Re the motors have you seen dyno charts - not just calculator graphs?
Lehner efficiency is OK, as are Hackers, which are same gen technology but
Neu
* make motors for planes - most use smooth cans - I know how Neus were introduced to marine racing I did it... when I raised their performnce on RRR many years ago.
* uses finer laminations and 4 pole is easier than 2 pole on ESC's and the designs 4 years old the 2280s date from the mid 90's
* have better peak efficiency (claims means nothing - dyno charts tell the real story) and also much better efficiency at low amps and very high amps ie a wider band of high efficincy - this is very important for cars which spend most time at very low amps - less than 50 amps but spike into the 150A's under acceleration and high loads
* produce more torque per amp - in practice this usually means they do more with less or they give harder acceleration or better runtime
* are lighter for the same power and torque - means better p:w ratios and handling
In a car the avergae amp draw is so low a motor with enough torque shouldnt require additional cooling. IMO this mean water cooling is a complicated and redundant.
However given that Lehner;s specs will be running out of it efficiency band most of the time due to the high iron losses at low power and will run hot with air cooling.
With electric bigger isnt better. The smallest possible motor with sufficient torque and the correct efficiency point is the way to go. Electric motors are like the rods and crank - they dont make power they just covert it and waste it to varying degrees. Only batteries make power.
Water cooling is used on race boats but the power throughput is 150-190 amps average... or about 5 times that of a car.
correct me if i am wrong, but i believe mckrill is doing the water cooling not out of necessity but for more the experience of doing something different, cool, and of scale realism.
as for the lehners running hot at low power, that is true. i bought a lehner 2250 to run in a 1/8 truggy. i knew it was way over powered so i expected that truggy to fly. well, i was disappointed. the temps were high which i could not figure out. then someone here on the forum bought the motor from me and explained i had it in too small of a car. he put it in a baja conversion and it ran cool as ever.
but here is something interesting. i love lehners, neus, and hackers. all are great motors if you ask me. i just built a slash 4x4 and put in a 1512 1y 2700kv on 3s. temps were pretty good. mostly in the 130 range but got up to 150 at one point. which is hotter than i like. so i put in a 1973kv b50xl hacker just to test. now temps are in the 105 to 110 range and the truck seems faster, or at least as fast. the same exact thing happened when i switched from 2200kv neu to 1973kv c50xl in my losi 8ight last year. lower temps, lower kv, but faster car. that has just been my experience.
Jammin SCRT10 Neu 1512 1y
