05.31.2010, 05:59 AM
Thanks for the help finnster, i hope i can run mech brakes, if and when i find an appropriate mount, i will look into the brakes. I just want a decent motor and diff mount.
I am a little worried about choosing the wrong spur gear which will have difficulties fitting. I may need some pics of the slipperential with the 58t spur on and see if it will work in a savage and has enough clearance.
Plus i am hoping it is quick and easy to change the spur on the slipperential as i will want to run a plastic spur vs a metal one so my pinion doesnt experience wear....
