05.31.2010, 10:06 PM
I think the 12mm to 17mm that mike make's look good but honestly i feel the same about hex going on hex. Honestly i have never tried them so i cannot say they are good or bad. They are kind of pricey and if they were a little cheaper i would try them in a heart beat. I dont have many 1/10 size vehicles or anything that really takes 12mm hex to justify buying them for one car when i can buy a set for $25 and under shipped that will work good. the flm protype set i had worked great and were cheap, i just did not like the fact that i had to use a metal type washer to hold the axle pins in place , could have been designed a lil better but then again it was a prototype. Nard Cox the mm is holding up good , my only problem is i am running a 7700kv motor and the motor gets a bit hot sometimes bc of long full throttle run's. I had the motor laying around so i figured id throw it in . I actually ziptied two novak esc heat sinks on top of my mm for extra cooling and it has been working out pretty good. I have been running stock pinion and spur on 2s so far. As for those slash 4x4 adapters , if i was going to use any i would get the aka racing ones , i had them on my slash 4x4 and they were top quality and worked great. But honestlty at that price if i was going to spend the money i would give rc monster mikes a shot.
