Krawlin
Got brushless?
Krawlin's Avatar
06.02.2010, 01:23 AM
Alright, some exact MGT arm measurements for ya....
Lower arm width at hinge pin holes - 1.910'', 48.51mm
Lower arm overall length from tip to tip - 5.406'' (5 13/32''), 137.312mm
Upper arm width at hinge pin holes - 2.755'', 69.977mm
Upper arm overall length from tip to tip - 4.945'', 125.603mm
Lower arm has 3 stubs for the hinge pin to go through, Maxx has 2. Upper arm have 2 small stubs and 1 large stub for the hinge pin to go through, Maxx has 4 small ones. Maxx upper arm has material running between the shocks, MGT stock upper arm does not (RPM MGT arms do though).
Hope this helps some!
One cool property that I found about the MGT arms is they can be melted back together and be used for quite some time after if done right. Not long after I got the truck (about 6 years ago, it was an original .21 MGT), I let my dad try it out, and he ran it into a tree within the first 2 minutes of running it, snapped the upper arm in 2 places. Used a soldering iron with large thin/flat tip, got it nice and hot, stuck it between the two pieces and let them melt pretty good then pulled the iron out and together and clamped the arm in a vice for a few minutes while it cooled. did that with the other area where it snapped and was able to put it all back together and I got quite a few runs from that arm before it snapped again. So with the stock MGT arms, if you want to keep running and don't have a spare and don't want to wait for another one in the mail, that works well in that kind of situation. I've never tried this with RPM arms or stock Maxx arms before though.
Monster GT Conversion
