Finnster
KillaHurtz
Finnster's Avatar
06.03.2010, 02:02 PM
I was considering doing that finnster with the braces but it if i can find another way of mounting it i would be happier.
I know this is a silly question, but i have never tried tapping my own holes. I know this would definitely benefit the mount and prevent any stripping. What specific tools would i need to do it?
All you need is a properly sized drill bit and a hand tap (and the tap wrench to hold it.) You first drill out the hole to the approx size, then run a hand tap down the hole which cuts the threads. Basically looks like a threaded drill bit.
You can get taps all over the place, but small metrics are not so common. I get mine from McMaster Carr, but I'm sure Harbor Freight or any other decent hardware dealer has them. M4x0.7mm and M3x.5mm are the most common sizes in RCs. Invaluable tools to have IMO.
Interesting idea about mounting the CD sideways. I wonder if it would fit inside TVPs tho.. Only 74mm clearance. You would not want to tap the thru hole, just the mount the screws are going into.
