zeropointbug
Z-Pinch racer
zeropointbug's Avatar
06.06.2010, 03:46 PM
Yeah man, the 720i HP is reporting them to be 1mOhm (probably the lowest it can go?) each. Cell_man did some discharge tests on endless sphere, can discharge 600amps @ 2.0v/cell IIRC. I am going to buy a 1200watt charger for it to get less than an hour 0-100% charge. If you calc the power density from the 26650 M1's, it should have a solid 17kW power capability, so obviously it's not going to break a sweat at ~2000watts peak.
Those holes look scary to me.
Oh, and do I need a torque arm for the rear?
