sluggie24
sluggie24's Avatar
02.19.2006, 06:38 PM
The 8xl + 9920 gives a ton of power on 20 cells. Probably more than most will ever need. but you will have to build your truck to take the power and not skimp on anything......as I found.....diff.... LOL I get great run time to boot. 15-20 mins running real hard. Would probably run longer if I took it easy but whats the fun in that??? I would reccomend using an extended chassis to help control the wheelies as a wheelie bar alone will not do it. (I just ordered the extended Gorilla Maxx for mine) 8xl on 20 cells will flip the truck right over the wheelie bar with 18/51 gears and 1/8 diffs at 2/3 trigger pull. I think 18 cells would be better for this motor for drivability. If you have your heart set on using 20 cells then 10xl might be the better one to use to keep it controlable. My opinion might change once I change my chassis and diffs. I will let you all know if the control issue is resovled with the longer chassis.
