Jahay
06.07.2010, 09:51 AM
The Tranny is my transmission. Of course my pinions are all hardened but the gears in side the tranny are not as great.
I dont wheelie all the time as my wheel base is 17" so around 23+" over all length. And as my motor is mounted at the front, the extra weight forward helps keep the nose down. But it still wheelies on grippy surfaces.
I do not have punch control set. It is at 0. Not necessary as i have so much weight forward. Plus you are comparing your 10lbs truggy to my 14-15lbs truck (depending on lipos used) .
