Comming out.
JERRY2KONE
JERRY2KONE SUPERMAXX
JERRY2KONE's Avatar
Comming out. - 06.07.2010, 07:05 PM
Some of the truth is slowly leaking out, and according to actual estimates the real level of the disaster is much worse than first reported(SURPRIZE). Considering that now BP is estimating that 500,000 to 1,000,000 gallons of oil has been leaking from the well each day. Multiply that average by what, 40 days there is already 20 to 40 million gallons of oil floating somewhere in the Gulf, that will eventually come a shore.
The only real solution for even begining to clean this mess up is to skim it off the top of the surface as it shows up with huge skimmer ships, and burn what is left. AND until they get this leak stopped it will do very little to stop the damage because we can not keep up with the amount of oil being released every day.
The real kicker here is that this dispersant that they have been spraying all over the oil only does one thing. It helps to sink the oil below the surface. What does that mean? Well if you have been watching the news they keep mentioning that there are plumes floating just below the surface. The dispersant does just that. It keeps it out of sight for a while and then eventually it comes back to the surface at a later date, giving everyone the ellusion that it is not all that bad up front. You can try an experiment in your own sink. Put some oil in a sink full of water, and squirt some Dawn onto the surface. Leave it and watch what happens.
SUPERMAXX YOUR LIFE.
