zeropointbug
Z-Pinch racer
zeropointbug's Avatar
06.08.2010, 02:24 AM
Okay, I went to my machinist today, brought him the plans for the battery pack terminal plate. Will be machined out of 1/2" poly, with 47mm x 2.3mm slots machined in for tabs to come through. Aluminum tabs measuring 65mm x 8mm and 3.125mm thick will be made (17 of them) to clamp down on the tabs connection.
I also got him to make a solid torque bar that mounts to the disc brake caliper mounting holes, so it should hold good and strong.
