mistercrash
Guelph, Canada, eh!
mistercrash's Avatar
06.09.2010, 11:42 AM
The brackets I made for the battery boxes are doing very well. I think I will go ahead with the making of the new chassis top plate with wings. It would make the whole chassis/batt box assembly a little cleaner with a bit less hardware. I just need to find the funding for another 9X14 CF sheet. If I can't then I might make it out of 6061 T6 alu since I have enough left to make a top plate. The rest of the truck is also doing very well except for the inner bearings of the rear knuckles. They are starting to seize so time for me to hit Avid RC for some new bearings. I made a thicker rear sway bar that is 3.1 mm in diameter. Good for racing I would say but a little stiff for bashing.
No brain, no headaches.
