Semi Pro
Semi Pro's Avatar
06.09.2010, 05:38 PM
Originally Posted by TexasSP View Post
It's kyosho so I know it will cost an arm and a leg and parts support will be almost non existent.
I also question the use of straight axles on a go fast machine and really don't care for the plastic links. The servo linkages for the steering appear that they will not hold up and catch on loose debris while off roading, and the plastic servo arm for a monster truck steering servo is pointless.
Over all not impressed and would not buy one as the other choices out there are proven.
have you ever owned one?
i have a twin force, its a tank, its 10 years old, its been used with many diffrent brushless setup and been in some of the worst rc crashes i have ever seen,in 10 years the only part to fail was a warped top shaft that sill worked but has a nasty looking wobble to it.
its a tried and true truck, its not going to win many races but i has out lasted every other rc in my group of freind.
