scarletboa
scarletboa's Avatar
06.09.2010, 08:07 PM
Originally Posted by blueb8llz View Post
great find! thanks a whole bunch. i didnt see these packs because i jumped to page 11 because the previous pages were lower mah packs.
but they do have some higher mah packs in the earlier pages.
but just a little too late, i ended up buying some neu energy 25c 5k hardcase lipos from rschoi__75 (member here on rcm) last night.
but still good to know, ill most likely be buying these turnigy packs sooner or later.
edit:after reading some reviews, someone stated that these packs are actually 47mm hieght. and the emaxx compartment is 45mm in height.
are you using these only in your flux, or do you have a emaxx as well?
i've seen these packs fit into an e-maxx with no issues. they also fit nicely in the e-revo as well. they have similar dimensions as a standard 6 cell ni-mh pack, only they are just a hair taller. the only issues with size i have heard of is in those tiny on-road 1/10 and 1/12 cars that are limited to 23mm height.
