mistercrash
Guelph, Canada, eh!
mistercrash's Avatar
06.10.2010, 02:07 PM
It might be something else but it sounds like a pinion has broken a tooth or two in one of the diffs. It's hard to see sometimes. You have to open the diff cases and clean the ring gear and pinion and inspect thoroughly. Use a magnifying glass if you have to.
No brain, no headaches.
