Thread
Will the Kyosho plastic spurs fit in the Jammin X2 CRT?
4
Gallagher
06.12.2010, 09:42 AM
You need shim the diff, since the diff will move backwards or forwards a little bit more than when you use the stock spur gear. I use washers to shim the bearing and the diff mount.
Gallagher
