06.14.2010, 10:21 AM
Ah, yes...
It is possible to use the new style slipper, but it requires some clever modification of the input ( top ) shaft:
http://www.rc-monster.com/forum/showthread.php?t=11589
Now, that^ is intended for the singlespeed emaxxtransmission, but I think if you used the input shaft from a newer style t-maxx ( which is longer and will fit the older style transmission hopefully ) you should be able to do the same modification basically.
As for the sizes of mod1 vs mod 0.8 gears, try this:
http://www.scriptasylum.com/rc_speed/_gear_calc.html
Just play with the sizes & tooth counts until you can find the equivelants in each size.
Also, try using this gearing calculator too:
http://www.scriptasylum.com/rc_speed/_top_speed.html
You wont need to worry much about the sizes of the gears ( spur and pinion ), since you are just aiming for a desired speed with whatever ratio is required.
Without knowing your full setup its impossible to guess the best/ possible options your have, but as an example:
Differential Ratio: 3.3076923076923075
Transmission Ratio: 1.7222222222222223
Other Ratio: 1
Spur Tooth Count: 66
Pinion Tooth Count: 24
Total Voltage: 14.8
Motor KV: 2200
Tire Diameter (inches): 5.75
Tire Ballooning (inches): 0
Motor Current Draw: 0
Motor Coil Resistance: 0.006
Spur/Pinion Ratio: 2.75 : 1
Total Ratio: 15.6656 : 1
Tire Circumference (inches): 18.06 inches (458.83 mm)
Rollout: 1.15:1
Total Motor Speed: 32560 RPM
Vehicle Speed: 35.55 mph (57.11 km/h)
Effective KV Value: 2200
Thats 24/66 gearing for 35mph with mod 0.8 gears. To get the same speed with mod 1 gears:
Other Ratio: 1
Spur Tooth Count: 68
Pinion Tooth Count: 25
Total Voltage: 14.8
Motor KV: 2200
Spur/Pinion Ratio: 2.72 : 1
Total Ratio: 15.4947 : 1
Rollout: 1.17:1
Vehicle Speed: 35.95 mph (57.74 km/h)
you would need 68/25- its not a big difference really, when using a transmission.
If you went with just a center differential unit ( with the slipperentialo maybe ), then the ratios would be very different as there arent as many gears to reduce the gear ratio obviously, but you would still just select mod 1 spurs and pinions that give you the desired speed- actual size doesnt matter so much, so long as they can actually fit / mesh together properly. If we copy the example above, then with a center differential unit you would need 46-48/10 or something in that region to get the same ~35mph speed.
