06.15.2010, 08:46 AM
Well, the G4 chassis has less room than the G2/ G3, since the stock tranny is narrower...
Since you wont need the tranny mounting points, theres no harm in cutting a slot either side ( seen a few guys do that actually ).
Custom drive shafts will be required really unless you get lucky- otherwise you can swap the output shafts/cups for the rc-monster shafts, then run the stock plastic drive shafts maybe.
