cabking
02.20.2006, 05:34 AM
I use banana plugs with the socket on the pack, so you can plug them together.
I have seen a set up with 2x 10mm studs in a block of wood wired up to the + and _. then you can use crock clips to clip to the studs.....................if that makes sense?
