MiamizFinest
MiamizFinest's Avatar
06.15.2010, 05:03 PM
Originally Posted by bryan View Post
Looks great , im getting some things together to convert my sons.That looks like a losi 8ight tray your using? How much did you have to do to the chassis to make it work "extra holes" ?
for the battery tray nothing was drilled the rear holes lined up fine with the motor mount holes in the chassis. The front hole ALMOST lines up with a hole already in the chassis its about 2MM off but with a 4MM screw threw the hole not only does it clear the hole perfectly it threads itself into the tray on its way up. All in all i only added one hole to the chassis and that was for the radiobox. Pretty simple and clean. I used the ofna radio box for a factory look.
