06.15.2010, 09:46 PM
I like Garc 7075 t6 for the front and FLM for the rear as FLM has a 3rd brace point on the rear for the hinge-pin, GARC doesn't. This makes a HUGE difference for me. The lists of differences is pretty big. GARC has a entry hole for the tower screw points, FLM doesn't. FLMs are always 6061, GARC can be 7075. FLM can be littler due to this, FLM will always regardless be lighter because of pocketing and smaller braces. GARC will be always be stronger because of the lack of pocketing. FLM has captured hinge pins using grub screws and does NOT use E-clips, GARC doesn't have this and DOES use E-clips. FLM can sometimes have clogged screw holes, GARC doesn't seem to posses this. FLM almost always has machining marks, GARC doesn't seem to.
FLM also offers Hybrid bulks which GARC doesn't.
Both are great! I've never seen a broken one, except for screws being broken off in them.
I wish I had a VBS.
Can't wait to see your project Klausen
-Zack
