NEW- Tekin SC motors
nitrostarter
nitrostarter's Avatar
NEW- Tekin SC motors - 06.18.2010, 04:32 PM
http://www.teamtekin.com/
Available mid July from Tekin. The Redline SC4X Sensored Motor series is Tekin’s latest contribution to high performance competition oriented components. Designed for the Pro4 Short Course class and can be used with any 1:10th scale 4wd Short Course chassis. The longer can and rotor provide more torque and lower temperatures keeping you ahead of the competition. Engineered for power and efficiency, Redline SC4X motors offer a superior and reliable platform for your 4wd Short Course needs.
Available in 4.5 and 5.5 turns.
Features:
Compatible with any sensored/sensorless ESC
CNC Machined Aluminum Heatsink Can
A.B.E.C. 5 Oversized Bearings
Neodymium Sintered Magnet
Specs:
6061 T6 Aluminum
Diameter 36mm x Length 72mm
Weight 8.36 oz / 237 grams
Shaft 15.3mm x 5mm
Sensored
SC4X 4.5 Turn part # TT2243
SC4X 5.5 Turn part # TT2242
Should be a great alternative to the Novaks!!!
N. Rustler conversion
