EDS
06.21.2010, 07:11 PM
you do understan that the rear wing greatly affects your center of gravity right, thats why we are mounting then as low as possable
other than that you need some sway bars
whats the weight of your roller?
I probaly could have mounted the wing slightly lower but not much.. because then the tires would rub on it when the suspension was compressed.
I installed sway bars on it.. you can see them in the picture of me holding the car.
I'm not sure of the weight of the roller.. Ill get a weight of it rtr though then can subtract the electronics from that number.
Killajb: too late haha I shipped it out today..
Finally I'm finished with this project...well for now..
I spent all yesterday trying to figure out why the center diff wasn't turning the rear diff smoothly. I ended up having to shim it with a spacer plate I made out of a divider you would find in fishing takkle box. I also replaced the rear out put on the center diff with the stock Rc8 outdrive and epoxied a pin in the output shaft of the revo diff. This is much smoother. I just up it will hold up. Last night I stayed up till about 3:30 doing finishing touch type of stuff like counter sinking the chassis, making body mounts,installing sway bars, making a extra battery compartment part, and generally making sure everything was ready for testing. I finished everything up this morning and packed it up and took it to the post office.. Should get to my friend on thursday. I was going to insure it.. but they said if it got lost I would need a receipt to make a claim with usps. Well how the heck do you have a receipt for a custom creation??? Anyway.. took a couple last pictures of it before I sent it out.. The creator with the creation
