sikeston34m
sikeston34m's Avatar
06.22.2010, 07:16 PM
Originally Posted by TexasSP View Post
I would agree completely with sikeston on this. This is one of the major advantages of LED back lit TV's and not too mention they are much thinner too.
This would be worth having it looked at and repaired for sure, especially if it was a moderate to higher end model.
It sounds like you've been into a few of them or at least did your homework.
I have a Polaroid 32" LCD with problems that I've been trying to figure out. These were notorious for blowing the guts out of several capacitors on the power supply. Thus creating symptoms like mine. Blue "power" light comes on, but no sound or picture.
Of course, I opened it up and all the power supply illustrations I could find, do NOT match my power supply.
My Capacitors appear to be intact, as does the voltage coming from the power supply. So I'm unsure and haven't been able to bring myself to throw it away yet. LOL Any ideas?
Thanks for the info on the LED TV's. I can see how that type of construction is going to last longer, use less power and also give off less heat.
